1995 Oldsmobile Cutlass Engine stall while driving
JAWS6947
  • 1995 OLDSMOBILE CUTLASS
  • 6 CYL
  • 186,547 MILES
After getting an oil change, two days later, my car began to smoke on way home on a freeway. Then just before getting to my exit, the car engine shut off. On further inspection, oil was burning, and radiator fluid was nill. Added water to check for leaks, there were none. Car has cooled, but engine won't fire. Starter is fine. Alternator is only 3 months old. Car will crank, but will not fire. Need help
Do you
have the same problem?
Saturday, November 14th, 2009 AT 10:50 AM
  • EXPERT
Are you getting spark and fuel to the engine?
Wednesday, November 18th, 2009 AT 10:54 AM
Recommended Guides
