1994 Oldsmobile Cutlass low milage hard start
ROSSG
  • 1994 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 78,000 MILES
I have a 3.4 liter olds cutlass that is currently getting 15mpg highway worse around town. It also cranks for a long time before it will start. The hard start is random sometimes it starts right up sometimes you have to crank it a couple times to get it to fire. If I put my foot to the floor on starting it starts faster but a big cloud comes out of the tail pipe that also sets a maf code 101. The maf is a reman and the car runs fine other than the starting problem. There are new plugs, wires air filter fuel filter and pcv in the car. It does run on all 6 cylinders but I am not sure if the plug wires for 6+3 are in the right place I have moved them back and forth and the car runs just about the same. They share the same coil pack.
Do you
have the same problem?
Monday, August 4th, 2008 AT 2:01 PM
ROSSG
Anyone know anything about this
Tuesday, August 12th, 2008 AT 5:05 PM
Recommended Guides
