1994 Oldsmobile Cutlass
MPOSA5478
  • 1994 OLDSMOBILE CUTLASS
Engine Performance problem
1994 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
how to check coils and ignition control mod.
Do you
have the same problem?
Tuesday, March 2nd, 2010 AT 1:57 PM
JDL
  • EXPERT
Hi, I always have to ask, how long since a tune-up? Did you visually check for spark at the plugs? Are there any trouble codes? I have heard, some of the national brand autostores can check ignition modules, I'm not sure. You can call and ask.
With dis ignition, I check B+ and ground at the ignition module, first. Go from there. Which Cutlass, there are usually several listed?
Tuesday, March 2nd, 2010 AT 2:08 PM
Recommended Guides
