1993 Oldsmobile Cutlass NO SPARK
ZOOM ZOOM 6
  • 1993 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 150,000 MILES
1993 OLDSMOBILE CUTLESS WITH 3.3L I RAN THE ENGINE (ABOUT 10 MILES) 3 MOUNTH AGO AND NOW THE ENGINE WILL CRANK AND NOT START, I TRACED IT TO NO SPARK, MY FATHER HAS THE SAME CAR AND I HAVE SWAPPED THE IGNITION COILS, IGNITION MODLE, CRANK SENSOR AND ECM AND STILL NO SPARK, I COULD REALLY USE SOME HELP (THERE IS 13V GOING TO THE IGNITION MODULE WHEN CRANKING)
Do you
have the same problem?
Saturday, July 31st, 2010 AT 3:28 PM
  • EXPERT
Are you getting power to the coil?
Friday, August 13th, 2010 AT 10:02 PM
Recommended Guides
