1988 Oldsmobile Cutlass runs and dies
JF1521
  • 1988 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 174,000 MILES
I have a 1988 olds cutluss with a 2.8 v6. If I put to hard on the gas seems like it chocks it self out. I put a new fuel pump in it and the fuel pressure is about 32-34 psi. I changed maf, map and its fires then dies, fires then dies ect. Onthe 10th to 15th time it might run good and it might not. Please HELP I'm going crazy. Thanks
Do you
have the same problem?
Tuesday, June 10th, 2008 AT 8:59 PM
LEGITIMATE007
  • EXPERT
Check the crank position sensor, it may be faulty
Tuesday, June 10th, 2008 AT 9:53 PM
Recommended Guides
