1987 Oldsmobile Bravada shift lever button
PATTED
  • 1987 OLDSMOBILE BRAVADA
Transmission problem
1987 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
Button on shift lever on the consul can, t be pushed in to shift from park to drive gears. Letting the engine idle for a while and you can shift.
Do you
have the same problem?
Thursday, January 15th, 2009 AT 9:32 AM
IMPALASS
  • EXPERT
Hello -
Just to make sure you vehicle is a 1997 not a 1987........correct?
Please try to turn the key to the Accessory (ACC) position and don't put your foot on the brake or anything and see if you can shift then?
Also try this test.
http://www.2carpros.com/forum/automotive_pictures/248015_Bravada_1.jpg
Thursday, January 15th, 2009 AT 6:06 PM
Recommended Guides
