1999 Oldsmobile Alero car overheats
BRINK4
  • 1999 OLDSMOBILE ALERO
  • 6 CYL
  • FWD
  • 137,000 MILES
Car overheats only when engine is cold. After it sits and cools down, you restart and it runs fine. Replaced thhe following < thermostat, waterpump, intake manifold gasket, dye test on head gasket (it was o.K.) Overflow tank cap, \ checked the following, heater bypass hose, heater core all hoses and fans, (they kick in correctly. Need help
Do you
have the same problem?
Friday, February 19th, 2010 AT 5:00 PM
  • EXPERT
Have you checked the engine compression?
Wednesday, April 7th, 2010 AT 1:40 PM
Recommended Guides
