1999 Oldsmobile Alero
SHELIA_BAKER5
  • 1999 OLDSMOBILE ALERO
  • 6 CYL
  • FWD
  • 170,000 MILES
Car will not turn over does not need a battery, has gas. Did the same thing last week sat for two days than strted up wit no problem> cuts off sometimes when I drive but will start back up.
Do you
have the same problem?
Monday, April 5th, 2010 AT 10:10 AM
LEGITIMATE007
  • EXPERT
Hi, ok, we need to establish a few things, hopefully you have a friend that can help you with this, we need to establish if the fuel pressure is low and if you are having and ignition problem, so we need to check fuel and spark.I'll send you info on how to do this
Wednesday, April 7th, 2010 AT 6:13 AM
LEGITIMATE007
  • EXPERT
http://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Wednesday, April 7th, 2010 AT 6:15 AM
LEGITIMATE007
  • EXPERT
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Wednesday, April 7th, 2010 AT 6:16 AM
Recommended Guides
