1995 Oldsmobile Achieva CAR WONT START
MATTHEWB507
  • 1995 OLDSMOBILE ACHIEVA
  • 4 CYL
  • FWD
  • 110,253 MILES
I have a 95 olds achivea that will not start you put the key in the ignition and turn over and it does not do anything normalyy you would hear it crank over to start it but there is dead siilence to it the battery is good and I took the starter out and went to have it tested and came up dead so bad that the auto parts store fuse blew in the back so I got a new one and put that into the car and tryed to start it again and still nothing no sound at all to it as if it trying to crank over so is there any other suggestions what might be the problem as to not turning over at all.
thanks
Do you
have the same problem?
Friday, July 10th, 2009 AT 1:46 PM
  • EXPERT
Have you checked the starter relay?
Thursday, August 20th, 2009 AT 2:44 PM
Recommended Guides
