1992 Oldsmobile Achieva SOC 4cyl runs bad wont start now
FIXITMR
  • 1992 OLDSMOBILE ACHIEVA
Engine Mechanical problem
1992 Oldsmobile Achieva 4 cyl Two Wheel Drive Automatic 170k miles
so my sister gives me this car. It has slight overheat problem. Dont let it idle too long! Gave to brother to drive and a miss developed. It got progressively worse until car would not start. Checked spark and plugs and all good. Did compression check and 1 cyl no compression another low. Started to tear down, took off cam and turned over engine. Now it has good compression on all 4! Checked timing chain was fine and timing marks lined up before removal. Is it the lifters? Can they cause no compression? Thanks
Do you
have the same problem?
Sunday, July 19th, 2009 AT 6:50 PM
  • EXPERT
If a valve stuck open, it could cause that.
Thursday, August 20th, 2009 AT 2:27 PM
Recommended Guides
