1996 Oldsmobile 98 heat blows cold air and engine over heat
RJHOLLIMAN
  • 1996 OLDSMOBILE 98
Air Conditioning problem
1996 Oldsmobile 98 6 cyl Front Wheel Drive Automatic
car overheats and blows cold air. Recently changed thermostat, & flushed radiator.
Do you
have the same problem?
Friday, November 28th, 2008 AT 8:39 AM
  • EXPERT
Hi:
Does it overheat at highway speeds? If so, the flush may not have gotten rid of the radiator problem. I want you to try something. With the engine COLD, remove the radiator cap. Next, start the engine and watch the coolant. When the engine reaches normal operating temp, the thermostat should fully open and you should see the coolant freely circulating in the radiator.
Let me know what you find.
Saturday, December 20th, 2008 AT 9:24 PM
Recommended Guides
