1998 Oldsmobile 88 wont start
SASH
  • 1998 OLDSMOBILE 88
  • 6 CYL
  • FWD
  • 130,000 MILES
My 1998 olds 88 ithat intermittently wont start. It runs fine when it does run. Itll start and run for days on end and occasionally wont start after many attempts at cranking it. After it sits for 15 minutes to a half hour it wiill start and run fine. This has been going on for a little over a month now. The times when it wont start I listen underneath and when the key is turned I dont hear the fuel pump. If anybody had any ideas let me know, thanks much, steve
Do you
have the same problem?
Saturday, May 22nd, 2010 AT 12:55 PM
Check and test the fuel pump relay
Saturday, May 22nd, 2010 AT 1:30 PM
Recommended Guides
