1994 Oldsmobile 88
RAY55555
  • 1994 OLDSMOBILE 88
  • 6 CYL
  • 100,000 MILES
Can you tell me if the firing order on a 1994 Olds Delta 88 goes from 1 to 6 with 1 being the shortest wire going to closest spark plug, 2 the next shortest wire, 3 the last short wire, and 4 opposite engine side (interior) closest spark plug, 5 and 6 following same pattern from cylinder numbers?
Do you
have the same problem?
Tuesday, February 17th, 2009 AT 12:34 PM
  • EXPERT
What size engine do you have?
Friday, February 20th, 2009 AT 10:42 AM
Recommended Guides
