1992 Oldsmobile 88 No Start / No Spark
MUSICMAN5282
  • 1992 OLDSMOBILE 88
  • 6 CYL
  • FWD
  • 168,000 MILES
I Have a 92 Oldsmobile that will not start. It was running perfectly fine, then died one day in the middle of a trip. I let it sit for a second then it fired back up, and hasn't started since then. The starter kickes in nice and strong, but there is no spark from any of the spark plugs. I have had the Ignition Control Module tested and it passed, and I have replaced the Camshaft sensor, Crankshaft sensor, oil sending unit, oil pressure unit, ECM. All three coils are fine, wires are all good, everything seems to be making good connections, but it just wont spark. Any Ideas? I'm at a loss.
Do you
have the same problem?
Thursday, September 9th, 2010 AT 2:15 PM
  • EXPERT
Are you getting power to the coil?
Sunday, October 24th, 2010 AT 11:17 PM
Recommended Guides
