1992 Oldsmobile 88 Car was stalling, now will not start
AWAYKENT
  • 1992 OLDSMOBILE 88
  • 6 CYL
  • 100,000 MILES
Car was stalling randomly, often would not start right away, now will not start at all. Replaced fuel filter, spark plugs, wires, coil, cam & crank sensors, module tested fine. Fuel pressure tested good although the plugs were dry when removed.
One question is what could stop the fuel from the port injectors getting into the cylinders.
Also, any other ideas on why it is not starting?
Do you
have the same problem?
Tuesday, April 14th, 2009 AT 3:16 PM
Check the fuel injectors for pulses
Tuesday, April 14th, 2009 AT 3:55 PM
Recommended Guides
