Oil sensor location
PUG2000_44216
  • 2007 FORD ESCAPE
  • 150,000 MILES
Where is oil sensor location?
Saturday, October 27th, 2018 AT 9:58 PM
  • 52,797 POSTS
Good morning.
There are two engines for your year. I attached pictures of the location for both the 4 cylinder and V6. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sunday, October 28th, 2018 AT 8:40 AM
RITA RASMUSSEN
  • 2005 FORD ESCAPE
  • 3.0L
  • 6 CYL
  • 4WD
  • 187,000 MILES
Need to put in new oil pressure sensor. Oil light sometimes comes on while idling. Where is the sensor?
Saturday, December 12th, 2020 AT 9:20 AM (Merged)
BMDOUBLE
  • 1,139 POSTS
It's near the oil filter location. I've attached a picture.
RITA RASMUSSEN
Thank you. Hope this is the problem!
DISCERNING2009
  • 2002 FORD ESCAPE
Engine Performance problem
2002 Ford Escape 6 cyl Four Wheel Drive Automatic
I am attempting to check the oil pressure at the oil sending switch and I was wondering what the psi and rpms should be. Also, I was attempting to check this because my original problem began with the oil light flickering only after my vehicle had been driven for at least 7 miles or idled for 10 minutes. I replaced the switch and changed my oil but the same problem persists. Furthermore, the light only flickers at idle or park until you turn the vehicle off for a moment and the process resets itself.
DISCERNING2009
I found the answer to my own question; 45 psi at 800 rpm.
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
first off, it would seem as though you may have a weak or failing oil pump. The oil pressure should be checked while engine is at operating temperature and it should be 54 - 80 psi at 4,000 RPMs.
DISCERNING2009
The psi was 85 @ 4000 rpms, therefore, the oil pump is ok but the problem might lay within the oil pan or more more specifically the oil pump tube and filter screen. That screen and tube will be my next task.
2 LINSEY
  • 287 POSTS
Hi thank you for using 2carpros. Com we hope you got you truck all figured out. Thanks again.
AUSSIEFORDESCAPE
How did you go with fixing your problem?
I have the same problem with my 2001 Foird Escape.
TIMGING
  • 2001 FORD ESCAPE
  • 4 CYL
  • 131,100 MILES
Where is the oil pressure sensor location on 2001 Ford Escape v-6
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,882 POSTS
Hey Timging,
Oil Pressure Switch (2.0L)On right rear near the starter under a bracket, here is a diagram (below) to help show you. I have also included the location for the V6 engine as well. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
RESTOINPOOL
Where is oil sensor on 2005 ford freestar
Wednesday, December 20th, 2023 AT 12:07 PM
KEN L
  • 42,882 POSTS
This thread is for a Ford Escape, sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Thursday, December 21st, 2023 AT 1:24 PM
