O/D off light flashing, no gear but reverse work.
BUSYBEE33
  • 2003 FORD ESCORT
  • 3.0L
  • V6
  • 4WD
  • 186,000 MILES
As I was driving my escape started to jerk and when I looked at the speedometer I noticed the O/D off light flashing and it felt as though it was slipping in and out of neutral. When I turned it off and started it again, I tried every gear one by one but the only gear that worked was reverse. All others felt as if I was in neutral.
I had someone look at it and they said they do not believe its the transmission. But the front right axle may have broken. The only thing I could think of other than the transmission is the universal axle. This is my first SUV let alone first Ford.
Do you
have the same problem?
Sunday, February 9th, 2014 AT 7:53 PM
CADIEMAN
Check the trans fluid.
Sunday, February 9th, 2014 AT 8:20 PM
Recommended Guides
