No working brake lights
TAMARA LYNN DAVIS
  • 2002 DODGE DURANGO
  • 5.9L
  • V8
  • RWD
  • 188,356 MILES
I have changed bulbs, checked fuses, and replaced the brake light switch. All lights work even the high mount brake light works. I have ran out of options can you help?
Do you
have the same problem?
Saturday, February 18th, 2017 AT 4:38 AM
STEVE W.
  • EXPERT
So all the tail and turn lights work, but not the brake lights? Remove the lamp housings and use a test light connected to a good ground to see if you have power to the white with tan wire with the brake pedal down, that is the stop light power. If nothing at either light you will need to follow the wire behind the left quarter panel trim, there is a splice there that may have failed.
Saturday, February 18th, 2017 AT 5:30 AM
Recommended Guides
