noise in right front of car
2003 MAZDA MPV
80,000 MILES
AZJENXAZ
chirping noise from inside right front side of van.stops when brakes are applied.just had rotors and pads replaced.doesn't make noise if I push up and down on car so I've eliminated suspension.tore apart front fender well and tightened all screws and bolts
Jun 27, 2013 at 9:12 PM
SEANGRANT00
  • EXPERT
  • 334 POSTS
This could be a couple things, I would probably first take it back to the place who did the breaks and have them look at it. If you take it anywhere else this could eliminate and liability on their part. This may end up being a simple fix as a wear indicator or something small. Take it back to them and let me know how it goes.
Sean
Jun 27, 2013 at 9:41 PM
AZJENXAZ
Thanks,I'll do that and let you know the outcome
Jun 27, 2013 at 9:47 PM
SEANGRANT00
  • EXPERT
  • 334 POSTS
brakes*
sounds good.
Jun 27, 2013 at 10:07 PM
AZJENXAZ
1st quality brakes and rotors were replaced from Big O that I've been going to for 25 years.Any further suggestions?
Jun 29, 2013 at 7:25 AM
SEANGRANT00
  • EXPERT
  • 334 POSTS
Well if the noise was not present before and then apparent after the work was done, it sounds like a brake issue. It could be the wear indicator, did you take it back and have them look at it?
Sean
Jun 29, 2013 at 1:28 PM
AZJENXAZ
Sorry for causing the confusion.It was chirping way before the brakes and rotors were changed.Your first suggestion about brake pads was where I thought the problems was.It still makes the same noise from what seems like the right side interior of the van.Any suggestions?
Jun 29, 2013 at 2:25 PM
SEANGRANT00
  • EXPERT
  • 334 POSTS
There was a bulletin from Mazda about the coil spring contacting/rubbing the inner fender liner. If you see a shiny part on the coil, near the top then that's the problem. I have attached an image also. Lets check this and then go from there
sean
Jun 30, 2013 at 11:53 PM
