No start when warm
CHRIS ROGERS
  • 2002 CHEVROLET MALIBU
  • 3.1L
  • 6 CYL
  • FWD
  • 147,546 MILES
Hi, my car will not start when warm. If you pull into a fuel station and turn it off it will crank fine, but not start for ten to thirty minutes. When it does restart it runs fine, no misfires, no codes. My scan tool reads rpm while cranking, so not crank sensor. Any ideas?
Do you
have the same problem?
Saturday, July 23rd, 2016 AT 8:12 AM
WRENCHTECH
  • EXPERT
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can only be tested during the failure. Any other time and they will simply test good because the problem is not present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That is what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the positive terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Saturday, July 23rd, 2016 AT 9:57 AM
Recommended Guides
