Engine shuts off bogs down while on highway and stalls?
JASON BROWN2
  • 1997 CHEVROLET SILVERADO
  • 7.4L
  • V8
  • 4WD
  • MANUAL
  • 173,390 MILES
I need a diagram of the intake egr, pvc, carbon can.
Tuesday, May 31st, 2016 AT 5:49 AM
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure as well as vacuum leaks auto parts scans for free and rent gauge. if hoses are soft for vacuum replace them.
and
https://www.2carpros.com/articles/engine-stalls
Check out the diagrams (Below). Please let us know what you find.
Tuesday, May 31st, 2016 AT 9:54 AM
DAVID7158
  • 10 POSTS
  • 213,150 MILES
When I put a load on and take it to 2,500 to 3,000 rpm's and let shift the engine bogs out and barely has enough power to move at 25 mph. Engine will completely shut off at this point if I open the throttle too far. This whole problem resolves itself if I park the truck and turn off for about ten to fifteen minutes.
Thursday, September 3rd, 2020 AT 12:30 PM (Merged)
  • 52,797 POSTS
Good afternoon,
This could be a couple of things.
Low fuel pressure from a weak fuel pump. The pressure needs to be checked.
It could also be a clogged catalytic converter. The back pressure needs to be checked to confirm.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
DAVID7158
  • 10 POSTS
Okay, thanks. I will look into it.
  • 52,797 POSTS
Keep us updated.
DAVID7158
  • 10 POSTS
This problem started after I replaced my rotor and cap. I forgot to include that.
  • 52,797 POSTS
Okay, start with verifying you installed it correctly.
DAVID7158
  • 10 POSTS
It should be. I put it back the way it came off. I did break the front screw thread so I got a c clamp on it.
  • 52,797 POSTS
Do the other checks.
DAVID7158
  • 10 POSTS
She has low fuel pressure and I don't know why cause I replaced everything in the fuel system injectors, pump, sending unit, fuel filter, the injectors came with a pressure regulator. The injectors are the mpfi upgrade over the sfi ones
  • 52,797 POSTS
What is the fuel pressure?
DKLEIN
  • 4 CYL
  • 4WD
  • 99,999 MILES
When accelerating normal everything is fine, but if I tromp down regardless of speed it slows down and almost dies out the tach doesnt jump like the trans. Is slipping but almost as if its dumping out
DENNYP
  • 1,823 POSTS
I dont recall a 4cyl in a silverado. Whatever it may be, you should check your fuel psi. If it's dropping off a lot under hard accelleration, you might have a bad fuel pump.
DAVID7158
  • 10 POSTS
22 to 23 psi.
  • 52,797 POSTS
What motor is in the truck?
DAVID7158
  • 10 POSTS
5.7 350.
  • 52,797 POSTS
Okay, Te specs are below.
Your pump is not working at all.
Fuel Pressure
Central SFI. 60-66 psi
SFI. 56-62 psi
DAVID7158
  • 10 POSTS
Okay, so pump is garbage then.
  • 52,797 POSTS
Yes, that is correct.
DAVID7158
  • 10 POSTS
Okay, thanks.
