No start
JFLETCHERGILBERT
  • 1999 DODGE DURANGO
  • 5.9L
  • V8
  • 4WD
  • 170 MILES
Fuel pressure good, turns over, has spark. No injector pulse and no codes. Was parked up on jacks for rear end for a month. They had very hard time taking back tire off ended up using a sledge hammer. Now it will not run. PCM not working to not throw codes. Maps sensor possible? Or anti-theft or rollover valve?
Do you
have the same problem?
Friday, June 2nd, 2017 AT 2:41 PM
JIS001
  • EXPERT
If you have no injector pulse and no codes, does the check engine light come on with the key on? If it does not verify proper power and ground to the computer. Also check all your fuses. The injectors all share the same 12 volt supply and all the computer does is ground the circuit to activate injectors. Verify you actually have 12 volts at the connector also if fuses are ok.
Sunday, June 4th, 2017 AT 8:16 PM
Recommended Guides
