No service lights, check engine lights, key won't hold in run position, car won't start
LOCKLIN58
  • 1998 BUICK LESABRE
  • 110,000 MILES
When I insert the key and turn it to the engine start position, nothing happens. No check engine lights, abs, brake, seat belt, or security lights. Jiggle the key a bit and the lights show and the starter turns over, but upon releasing of the key the engine dies. I have already replaced the key lock cylinder with new security key, with the same results. Would really like to know what the problem is.
Do you
have the same problem?
Monday, June 3rd, 2013 AT 11:27 PM
HMAC300
  • EXPERT
Sounds like a bad ignition switch
Tuesday, June 4th, 2013 AT 5:03 AM
Recommended Guides
