No crank when hot
BRANDONB
  • 2008 FORD F-150
  • 5.4L
  • V8
  • 4WD
  • 152,000 MILES
If I drive my truck for 5 plus minutes then turn it off it won't start. No crank, all electronics come on. Once cooled off it starts just fine. Only happens when it is hot outside I never have issues when temperatures are cooler. I have replaced the starter, checked for corrosion, swapped relays, and checked fuses. Like I said it only happens when hot after driving.
Do you
have the same problem?
Monday, April 5th, 2021 AT 8:59 PM
  • EXPERT
Good morning,
I would start with checking the battery and the connections. A weak battery or dirty connections will cause this issue.
I would also check for voltage to the starter solenoid when it does not start to verify the available voltage.
Tuesday, April 6th, 2021 AT 4:05 AM
