No AC
JOSE RICARDO KIKI GONZALEZ
  • 1995 GMC SIERRA
  • 5.6L
  • V8
  • 4WD
  • 300,000 MILES
K2500. Not sure if this the problem but on the climate control A/C button it doesn't light. So the compressor to HVAC doesn't turn on. Only blows hot air. Not sure what I can check or is it something else. Just need advice.
Do you
have the same problem?
Monday, May 13th, 2019 AT 5:22 PM
  • EXPERT
Good afternoon,
Do you have gauges to check the pressures on the high and low sides?
Did you check all the fuses for power on both sides?
Monday, May 13th, 2019 AT 5:43 PM
I already checked the gauges also tried to add Freon just wanting to let you know. At first it only was blowing below but corrected that. As for the gauges to check the pressure I don't have one personally yet.
Monday, May 13th, 2019 AT 6:55 PM
  • EXPERT
You checked the gauges but you don't have gauges to check?
Please explain? What were the pressures?
Monday, May 13th, 2019 AT 7:00 PM
Sorry, I meant I check the fuses.
Monday, May 13th, 2019 AT 10:23 PM
  • EXPERT
Did you check for power at the fuses with a test light?
Can you give me numbers on the gauges? I need this information to help you.
Tuesday, May 14th, 2019 AT 6:15 AM
