Air Conditioning does not work
HOCSINH
  • 2001 NISSAN XTERRA
  • 6 CYL
  • FWD
  • 87,000 MILES
I have my car AC service for like 6 months ago. My AC always blows out cold air whether or not I turn on my AC. But now I did not get the cool/cold air, but only warm air when AC is on or off
Any advice appreciated.
Tuesday, May 27th, 2008 AT 12:25 PM
KHLOW2008
  • 41,815 POSTS
Hi hocsinh,
Without AC on how to get cool air? I am a confused.
Check for compressor operations with AC on.
Check positioning of venting system.
Check heater control cable adjustment. This guide will help
Monday, June 9th, 2008 AT 11:11 AM
HOCSINH
  • 5 POSTS
The AC is on
the compressor is running when I checked
the air is warm whether or not the vent is on or off
i can hear some kind of noise from the passenger's side. Is that meant there is a leak?
What else should I check?
Thanks.
Thursday, June 12th, 2008 AT 4:30 PM
KHLOW2008
  • 41,815 POSTS
Hi hocsinh,
If there is noise from the passenger side, could be the expansion valve.
Get a pressure test on the system and let us know the readings.
Friday, June 13th, 2008 AT 8:20 AM
HOCSINH
  • 5 POSTS
Thanks a lot for your replies, KHLow2008
Finally, I brought my car to the auto shop dealer for the AC check and there is a leak from the high pressure pipe/tube as they told me
how easy and how much it costs to replace the pipe/tube estimately?
Thanks.
Saturday, June 14th, 2008 AT 1:02 PM
HOCSINH
  • 5 POSTS
Another mechanic checked and told me the leak is coming from the AC evaporator and it would cost $690 to fix it.
I am not sure who is to believe?
Any suggestion?
Thanks!
Saturday, June 14th, 2008 AT 2:26 PM
KHLOW2008
  • 41,815 POSTS
Hi hocsinh,
Sorry I can't help you about the price. But the pipe repair should cost less.
Since 2 person have told you 2 different possibilities, you might need a 3rd opinion.
Saturday, June 14th, 2008 AT 3:47 PM
HOCSINH
  • 5 POSTS
Thank you, KHLow2008
Saturday, June 14th, 2008 AT 4:29 PM
DANNY BLACKBURN
  • 11 POSTS
Replace the high pressure line yourself. Buy a new line or go to junk yard and get one and charge the system up before spending lots of money.
Thursday, June 6th, 2019 AT 7:24 AM
ROSEMEADE908
  • 2000 NISSAN XTERRA
My air conditioning just stopped working, when I press the AC nothing happens, before I could immediately hear the compressor turn on. I could not find a fuse in the under dash fuse box, is there another fuse box? Is the AC not working?
Monday, September 16th, 2019 AT 9:47 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Check the engine compartment also is the system fully charged?
This guide should help
ROSEMEADE908
Engine compartment, is where another fuse box would be located?
Also even if the system needed charging would the compressor still turn on but just blow warm air?
DOCFIXIT
  • 18,828 POSTS
Box under hood probably near batt.
System has low pressure cutout switch so comp. Will not run when system is low to prevent damage to comp.
TLANE77785
Air Conditioning problem
2001 Nissan Xterra Automatic
My air conditioning smells like an odor! Where is it located on the car so I can get the filter cleaned. It smells like body odor! I really need to change this out this smell makes me want to vomit.
DOCFIXIT
  • 18,828 POSTS
Your vehicle does not have a filter. Most likely mold in evaporator or a little critter got in intake vent. See diagram take motor out spray Febreeze and water bleach solution.
ALX2979
  • 6 CYL
  • 4WD
  • 113,000 MILES
Hello I have my xterra, my ac is not working I just put 134a+ refrigerant just install new thermal control amplifier new pressure switch my ac light in my dash comes on compressor is good can you guys help me please thank you
Could be still low in freon-Do you hear the clutch engage the compressor
ALX2979
This is what I did In fuse box I found the compressor fuse I brige from the batery + to the wire the goes to the compressor Works and I can get cool air but when I put the fuse back stops working like I say the ligh in the dash it's on the pipes on gets cool and the other one gets hot it's that normal? I change the bottom in the dash to any idea
Check and test the AC clutch relay and the pressue switch
ALX2979
The a/c clutch relay it's new and the presure swich is new and I getting power
DANNY BLACKBURN
  • 11 POSTS
I have a 2000 Xterra and air just quit working. Compressor wouldn't come on and light was coming on. The 4 wire plug on top of bottle on pass side, I pulled it out and put back in an tried to get plug out on top of compressor but couldnt get it come out. I tried it again and it started working. Check all your plugs, one of them might not be getting connection.
