Starting Question
HOLLYU
  • NISSAN SENTRA
2003 Nissan Sentra GE, Mileage: 37,000 miles.
Quick question for you - my car sometimes hesitates before starting. It seems to crank strong, but sometimes there is a hesitation of several engine rotations before it fires. It has had to crank for up to 5 seconds before starting. The problem seems intermittent and appears to be independant to whether the car is cold or warmed up. I can start and turn off the car repeatedly and the problem sometime surfaces, and sometimes doesn't.
Otherwise it runs great! Any suggestions?
Do you
have the same problem?
Tuesday, April 17th, 2007 AT 11:58 PM
Check the coolant temperature sensor.
Wednesday, April 18th, 2007 AT 4:41 AM
Recommended Guides
