2002 Nissan Sentra Engine shuts down
BOB BOWERS
  • 2002 NISSAN SENTRA
  • 4 CYL
  • 200,000 MILES
The engine shuts down for no apparent reason. I do not get a code on my code reader. After 10 minutes or so the engine will start ok. It almost seemsas if it is a heat sensor problem and when the heat cools it resets itself and the engine will start. After a few more minutes of driving it shuts off again.
Do you
have the same problem?
Sunday, May 3rd, 2009 AT 12:17 PM
ZACKMAN
I would check to make sure both camshaft and crankshaft position sensors are within specs. The ECM uses them for timing and fuel delivery.
Monday, May 11th, 2009 AT 2:47 AM
Recommended Guides
