Horn will not work
ANONYMOUS
  • 2005 NISSAN SENTRA
  • 52,000 MILES
One night I slammed on the horn button to avoid an accident, since then the horn will not work.
Tuesday, December 25th, 2012 AT 12:31 AM
  • 52,797 POSTS
The horn pad may be damaged. It most likely needs to be replaced.
It may be part of the air bag. Call the dealer and ask them if it can be purchased separately
Tuesday, December 25th, 2012 AT 12:44 AM
KHLOW2008
  • 41,815 POSTS
Check the fuse and horn first.
Tuesday, December 25th, 2012 AT 2:08 AM
MICHAELKSMITH1970
  • 2002 NISSAN SENTRA
  • 1.8L
  • 4 CYL
  • 120,000 MILES
Horn does not work. Twelve volt system with good battery. When ignition is on there is only 6.8 volts and one and five on the horn relay. Have no idea why.
Monday, May 11th, 2020 AT 11:47 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
Here is a wiring diagram (below) for the horn and a couple of guides to help you do some testing. Unplug the horns while testing it sounds like it might be shorted out.
and
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
MICHAELKSMITH1970
This doesnt help. I am a mechanic and an electrician so I know how to troubleshoot and have already taken those steps. What I need help understanding is why the relay block is only receiving 6 volts when there is NO short in the system.
KEN L
  • 42,883 POSTS
How many volts does the battery have? There is a main feed into the fuse block if you have 12 volts there then the fuse block is bad and needs replacement or repair. I would check the power coming off of the ignition switch and accessory relay as well.
Here are more wiring diagrams (below)
ZELLDOG93
  • 111 POSTS
  • 4 CYL
  • FWD
  • 100,600 MILES
Why wont my horn work in my 2002 nissan sentra gxe? I have replaced the relay the horn its self and the fuse that is meant for the horn.
Sounds like you need to open it up and check the horn button switch
ZELLDOG93
  • 111 POSTS
So you mean that I have to take apart my steering wheel? I havent done that yet would you be able to explain how to do it safely? Or send me a link that explains?
NONDRIVER
  • 2000 NISSAN SENTRA
Engine light stays on and horn doesn't work. If it is a fuse how do I know which fuse goes to what?
  • 108,179 POSTS
The owner's manual should show which fuse is for the horn. However, that has nothing to do with the check engine light. You need to have the computer scanned to determine what trouble code/s are stored in the car's computer. Most parts stores will do it for free.
88COOLJ
  • 6 POSTS
  • 4 CYL
  • FWD
  • 164,000 MILES
The horn does not work. I have checked all the fuses and all ok. I have check the horn itself it works. Is there any other fuses or relays under the hood that I can check or replace.
BLUELIGHTNIN6
  • 16,542 POSTS
Check horn relay, it is located on the fuse block (behind left side of dash)..
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_269.jpg
LAB
  • 1997 NISSAN SENTRA
  • 6 CYL
  • FWD
  • 53,000 MILES
Suddently the horn on this car is not working. As you can see with the mileage it has not been driven much because it is owned by a senior citizen who rarely drives.
Can you advise on repair, can we do this ourselves for her? Thanks
ZACKMAN
  • 4,202 POSTS
B14 Sentra horn has a tendency to just quit working. I advise that you replace it with an aftermarket one from any auto parts store. Should cost around $15.
