2000 Nissan Sentra fuel pump
FREAKDOGSLIM
  • 2000 NISSAN SENTRA
  • 4 CYL
  • 165,000 MILES
How do you replace the fuel pump and filter?
Do you
have the same problem?
Thursday, April 29th, 2010 AT 9:16 AM
KHLOW2008
  • EXPERT
Hi freakdogslim,
Here are the procedures.
FUEL PUMP, FUEL LEVEL SENSOR & FUEL FILTER -
http://www.2carpros.com/forum/automotive_pictures/192750_FuelPump00SentraFig02_1.jpg
Removal & Installation
1. Release fuel pressure. Remove access cover located under rear seat. Disconnect fuel hoses and electrical connector. Remove fuel pump assembly screws. Remove fuel pump assembly from fuel tank.
2. Using a screwdriver, disengage clips holding fuel pump assembly to chamber, in order shown in illustration. See Fig. 3. Disengage fuel tank temperature sensor wiring harness. Disengage clips holding fuel level sensor to chamber. Pull fuel level sensor upward.
3. Disconnect fuel pump harness connector. Disconnect hoses from fuel level sensor unit. Pull fuel level sensor unit upward and out of chamber. Disengage locking tabs holding fuel filter into chamber.
4. Pull fuel filter out of chamber. Using a screwdriver, remove fuel pump bracket. Pull fuel pump out of fuel filter. To install, reverse removal procedure. Tighten bolts to specification.
http://www.2carpros.com/forum/automotive_pictures/192750_FuelPump00SentraFig03_1.jpg
Thursday, April 29th, 2010 AT 10:21 AM
Recommended Guides
