Stuck in gear not shifting?
ANONYMOUS
  • 2007 NISSAN SENTRA
  • 94,500 MILES
What would cause my automatic transmission to be slow it shift and makes the engine rpms go to 4 to 5000 rpms. The only way it shifts is if I let off the gas and no codes are popping up?
Wednesday, February 6th, 2013 AT 5:35 PM
Sounds like its slipping bad-Check fluid condition and level if okay it sounds like the revolution sensor is bad.
Wednesday, February 6th, 2013 AT 7:56 PM
AMINCER1965
  • 2000 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 68,000 MILES
The car starts and runs fine. It won't shift, it seems to be stuck in third gear because when you start out there is no power until you get up to speed. Once you hit about 60 mph the tach reads about 4000 rpm's and wont shift into the last high gear. It shifts into reverse fine. I replaced the transmission filter and fluid, it run fine for a little while. If you let the car sit over night it will shift fine for a bit then back to being stuck in that higher gear. Can you give me some advice.
Thank you,
mark mincer
Monday, April 13th, 2020 AT 10:27 AM (Merged)
MARCSSENTRA
As soon as I start driving the car, its already in third gear! I have a 2000 Nissan sentra too. I don't know whats wrong.
Marc Robinson
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,878 POSTS
This sounds like an input shaft speed sensor is bad but to be sure lets run the codes here is a guide to help with the sensor location in the diagrams below.
ROSSDLOVER
  • 9 POSTS
  • 2002 NISSAN SENTRA
  • 1.8L
  • 4 CYL
  • 80,000 MILES
Car is throwing a code P0750. Staying in 3rd gear half the time. Reading this found be the connector on the transmission by the drivers tire or it is in need of a filter and transmission fluid change? Please help
HMAC300
  • 48,601 POSTS
Have a trans guy scan this, it's a shift solenoid problem which could be clutch or seal failures as well as another valve body problem or wiring issue. A fluid change will probably not hel p this.
FRANK GOOGS
  • 2001 NISSAN SENTRA
Transmission problem
2001 Nissan Sentra 4 cyl Two Wheel Drive Automatic
trans shifts hard code po710
  • 31,938 POSTS
Hi there,
This is the trans oil temp sensor circuit, is the oil dirty and smelly? You may have slippage problems, I would get this checked out by a trans specialist ASAP.
Mark (mhpautos)
MISSCOLLINS
  • 4 CYL
  • FWD
  • 104,000 MILES
One week ago my I was driving my car, an it struggle very badly to get into the next gear, but when it gets there it drives fine, could u please give me a straight answer on whats going on, when I took it to mechanic they told me I needed a new transmisson, but I dont believe it, because my car backs up fine the transmisson doesnt slip a all it just struggles to get to a next gear
Monday, April 13th, 2020 AT 10:29 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
When you say it struggles, do you mean the idle is raising beyond when it would normally shift? When it does shift does it shift hard?
How often was the fluid changed and what does the condition of it look like?
IS there a check engine light on?
I would not say the transmission is good because it only works in reverse corectly.
JASON BENDER
  • 2005 NISSAN SENTRA
  • 1.2L
  • 4 CYL
  • FWD
  • 100,000 MILES
When I start off the car drives fine then out of the blue I have no power. It is like the car is in neutral. When I tap the gas the engine does not rev and it last about thirty to sixty seconds and then it pops back into a gear. I then it goes for a bit and dies if I put the transmission into reverse. This has happened to me twice. Now after ten minutes of in and out the car runs fine. It has been four days in between episodes. What is causing this? I have checked the fluid and it is good. Please help.
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge auto parts rent it.
JAMESSGRIG
  • 97,000 MILES
I have a 02 Nissan sentra xe 1.8 auto with 97 thousand miles and while driving and deceleration the car will jerk like as if it was a standard trans and I let out on the clutch and pressed it again. What could be going wrong it
Monday, April 13th, 2020 AT 10:30 AM (Merged)
Do you have a check engine light and when was last tune-up?
Check the fuel pressure -start here
JAMESSGRIG
No the check engine lights are not on and the last service I had was about 500 miles ago. Had the oil and the air cleaner changed then the fuel injecters serviced
Have the fuel pressure checked and also the TPS and MAF sensors
96NISSANSENTRA
  • 1996 NISSAN SENTRA
1996 Nissan Sentra 4 cyl Automatic 164000 miles
My automatic wont shift into 3rd gear. Its fine when it goes into 1st and 2nd gear but as soon as it gets over 40mph it wont shift. The engine just revs and revs. I hear a clicking sound when it revs too. What could be the problem?
Check and test the throttle position and vehicle speed sensors-The computer uses these input signals from this sensors to comand and control the shifting solenoids to upshift/downshift/overdrive/lock-up
96NISSANSENTRA
Where exactly would I find the speed sensors at?
The VSS is located on rear of transaxle-Good Luck
