1995 Nissan Sentra Not Starting
MOORE.BRIAN99
  • 1995 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 93,000 MILES
95 Sentra Won't Start- batt. Terminals are clean, jumping the car off didn't work - no clicking during the start. Potential problem?
Do you
have the same problem?
Monday, July 7th, 2008 AT 11:08 AM
KHLOW2008
  • EXPERT
Hi Moore,
Should be starter and cranking circuit.
Pull starter solenoid wire out and get some one to crank the engine whaile you test the wire for power supply. If there is, apply direct battery current to starter solenoid to see if it works.
If no, tap the starter motor with a hammer and test again, if it works or tries to or won't work, the starter is bad. Hope the battery cable is ok. Check cable is broken.
Wednesday, July 9th, 2008 AT 5:41 AM
Recommended Guides
