1995 Nissan Sentra GXE Won't start when outside temp is HOT
JC2DAC
  • 1995 NISSAN SENTRA
1995 Nissan Sentra:
My car will start when temps are below 90 degrees, but anything above that, the car won't even turn over. As it is, I have to jiggle the key to start the car, but when above 90 degrees, it doesn't even turn over. The battery is good, all the normal things turn on when the key is engaged, it just doesn't turn over. What could be the problem? Would the ignition coil cause this problem in the heat if it were going bad?
Do you
have the same problem?
Friday, August 17th, 2007 AT 8:39 AM
Is it a GA16DE or 2.0L Auto or Manual tranny
What do you mean by this: it just doesn't turn over.
Do you mean it doesn't crank over or it cranks and refuses to start I need this answered before I continue.
GA16DE
Check the fuse D 10amp
Inhibitor relay in relay box front left engine compartment
Or it could be the ignition switch
2.0L
Inhibitor switch at transmission also called the neutral safety switch.
Note: There's no starter relay for both.
Friday, August 17th, 2007 AT 6:47 PM
JC2DAC
It an automatic 2.0 and it won't turn over. It doesn't crank
Sunday, August 19th, 2007 AT 7:59 AM
Cheap tool get a remote starter find the starter circuit on the starter connect the clip to it and other to the battery cable on the starter-Push the button did the starter crank over. You need to answer this before we can proceed.
Sunday, August 19th, 2007 AT 4:54 PM
Recommended Guides
