1994 Nissan Sentra my car wont start
WIWIWA
  • 1994 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 190,000 MILES
HI I would be very thankfull if you guys give me some tips Ichanged the fuel pump, filter, clean the hoses and the car still does not start it seems like the new pump. Does not pump up the gas to the engine
Do you
have the same problem?
Friday, December 4th, 2009 AT 8:54 PM
  • EXPERT
Were you getting power to the fuel pump when you replaced it? Have you checked for fuel pump pressure? Here is a how to for checking:
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Finally, have you checked to make sure the fuel pump relay is good.
I want you to try a test. See if the car will start for a few seconds with starting fluid and let me know what you find.
Monday, December 21st, 2009 AT 10:15 PM
Recommended Guides
