1999 Nissan Quest Nissan Quest 1999 Airbag light flashing.
VICAUTO2
  • 1999 NISSAN QUEST
1999 Nissan Quest 6 cyl Front Wheel Drive Automatic 116.00 miles
Hi.
I have previous post on (low speed fan not turning on), this is a same van.
Now Air bag light is flashing, When I replaced ECM and removed A/C evaperator and also removed all stuffs in front dash, I disarmed the air bag both side by unpluged 2pin plug on both side, and removed front chairs and 2 back raw seats, too, for cleant up.
After completed put back every thing when I removed, eccept 2 back raw seat, because I don't need them any more. But Airbag is still flashing.
I scan OBDII, but no code for airbag.
please, Some one tell me what I was doing wrong.
Or Is it bacause of 2 back raw seat removed? Any helps will be Thank you
Do you
have the same problem?
Friday, July 10th, 2009 AT 8:16 PM
BMRFIXIT
  • EXPERT
In some cases if the PCM replaced and not programmed, Air Bag light will come on or flash
rear seat will not cause an air bag on
OBDII reader will not get you to the air bag codes need to use a scanner
To enter self-diagnostics and retrieve fault codes,
open driver-side door, turn ignition on and immediately turn driver door switch (dome light switch) on and off more than 5 times within 7 seconds of turning ignition on. This changes self-diagnostic mode from USER mode to PRESENT DIAGNOSIS mode.
In PRESENT DIAGNOSIS mode:
If light flashes a marker sequence (7 seconds ON, 2 seconds OFF, 3 seconds ON, 2 seconds OFF) and then flashes quickly, record quick flashes. Quick flashes represent fault codes. For example, one quick flash represents Fault Code 1. Four quick flashes represents Fault Code 4.
If light flashes slowly and continuously (3 seconds ON, 2 seconds OFF), a fault occurred but is no longer present (intermittent fault).
Turn ignition off and disconnect both battery cables. Repair system. After repairing air bag system, connect battery cables, open driver-side door and turn ignition on.
If light flashes a marker sequence (7 seconds ON, 2 seconds OFF, 3 seconds ON) and does not begin a series of quick flashes, no malfunction is detected and no further repair is required. Turn ignition off and reset from DIAGNOSIS mode to USER mode.
If light flashes a marker sequence (7 seconds ON, 2 seconds OFF, 3 seconds ON) and begins series of quick flashes, the system has a problem and must be repaired.
Good luck
Saturday, July 11th, 2009 AT 7:29 AM
VICAUTO2
Hi !
Thank you for quick responding, I followed your instruction, the air bag light stayed on about 7sc and then flashed every seconds could not track what's code #.
Do you think the Air bag modoule is bad? It is at bottom floor below sterio console. The air bag did not explose yet . The problem need to be pinpoint before it can fix.
I have Nissan Exter 2002 no airbag, from savaged tittle. No airbag light flash and no any code, SUV is still running for 5 years, I don't know How they did that.
Can you tell me more details instruction reset air bag? If you can. Or some one Please !
Thank you
Sunday, July 12th, 2009 AT 6:38 AM
BMRFIXIT
  • EXPERT
If can not get the codes through the flashing
should have it scanned for codes
this way you pin point exactly what happening
(I would suspect a clock spring in the steering wheel )
but codes should help in identifying the exact problem
as it may be a connector not seated well
by disconnecting the battery should all reset if light comes back on repair was not done and problem still exist module detected a failure
Sunday, July 12th, 2009 AT 7:11 AM
VICAUTO2
Hi.
I'm dead in water, I have scaned OBDII, but no code, I also read all the code vehicle that ODBII can have, But not any code for air bag.
I did not touch any thing on clockspring, Just disarm 2 pin connector both side and disconnected power yellow line,
Some one know How to reset Air bag or some thing is about it. Please tell me
Any helps will be appreciated.
Sunday, July 12th, 2009 AT 2:29 PM
BMRFIXIT
  • EXPERT
Hello and I m sorry
but OBDII scanner /reader will not access the airbag system
you need a full scanner and NOT an OBDII reader
did you disconnect or remove the steering wheel?
CLEARING CODES Without CONSULT Tester
After system is repaired, turn ignition switch to OFF position for at least one second then, turn to ON position. DIAGNOSIS mode returns to USER mode and self-diagnosis result is cleared.
Sunday, July 12th, 2009 AT 10:20 PM
VICAUTO2
Hi.
Do you know more than that about air bag? Do you know what's kind of tool for full scan air bag? Do you have diagram of air bag, sensor location, module testing, and wire connection e.T.
Totally you don't know much about air bag system, every thing is claim for full scan fix it. I 'm not satisfy with the answare.
I understand some problem could not solve on line, because acknoleage limmit, not right person, I'm still seeking maricles to fix my van.
Any helps is wellcome, Thank you
Monday, July 13th, 2009 AT 4:26 AM
BMRFIXIT
  • EXPERT
SPECIAL SERVICE TOOLS
Tool NameTool Number
Air Bag Deployment ToolJ38381
Air Bag Deployment KitJ38381-KIT
Deployment Tool AdaptersJ38381-30
Air Bag Module BracketJ41246
Torx Bit (Tamper Resistant, T50)J38219
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_420.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_210.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic3_101.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic4_49.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic6_18.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic7_15.jpg
Monday, July 13th, 2009 AT 7:42 PM
VICAUTO2
Hi !
I've got my air bag lamp fixed, No more scare air bag lamp again.
Once again Thank you very much 2carpro supprt team, Do you overhaul Automatic transmission on line? Just wandering
Tuesday, July 14th, 2009 AT 5:51 PM
Recommended Guides
