1998 Nissan Pathfinder
POTENT.44
  • 1998 NISSAN PATHFINDER
Air Conditioning problem
1998 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic
ac is not working. System is fully charged with 134a. Compressor can be jumped at pressure switch and compressor will run but no matter how low you turn the temperature in the dash there is no change. Also ac will not turn on at the dash. Ac switch/ temp switch problem?
Do you
have the same problem?
Thursday, July 9th, 2009 AT 1:56 PM
DOCFIXIT
  • EXPERT
What are the high and low side readings?
Thursday, July 9th, 2009 AT 2:02 PM
Recommended Guides
