How to open up the inside of the door panel
ANJAIP
  • NISSAN
I have 1.0l Nissan Micra 1998 Twister Model. The manually operated window no longer operates (i.E. The winding handle no longer moves the window). Im pretty sure its that wire is snapped inside but I can't the inside panel removed to get at it. I can take the handle off by removing the small horseshoe clip between the handle and the panel and I can pull the outer edge of the panel out (these are just small plastic retaining plugs) but there still seems to be something else holding the plastic panel in place. Can you help.
Do you
have the same problem?
Saturday, April 7th, 2007 AT 6:21 AM
DAVE H
  • EXPERT
Remove the screws in the door handle !
Sunday, May 3rd, 2009 AT 5:56 AM
Recommended Guides
