2004 Nissan Micra blocking of key for start
JOLOPE
  • 2004 NISSAN MICRA
Electrical problem
2004 Nissan Micra 4 cyl Front Wheel Drive Manual
my nissan micra model kappa has the problem that sometime the starter button can not be turned it is blocked. Sometime I can not place the starter button in locked position it is blocked, this problem means that anyone can start the car and can get access because when the starter button can not be turned to locked pos. The doorlock does not work. Can you help? The dealer has tried several times and even the "black control box" is changed, still with the same problem.
I am waiting and hoping for help
Kind regards
John petersen
Do you
have the same problem?
Monday, June 1st, 2009 AT 3:11 AM
DAVE H
  • EXPERT
Try replacing the switch/button unit !
Wednesday, September 16th, 2009 AT 5:03 AM
Recommended Guides
