2000 Nissan Maxima orange engine light plus battery light co
BRIBO
  • 2000 NISSAN MAXIMA
Electrical problem
2000 Nissan Maxima Two Wheel Drive Manual 176000 miles
176000 the car is a nissan micra 1.4
Do you
have the same problem?
Wednesday, December 5th, 2007 AT 4:33 PM
  • EXPERT
Hi there,
Make sure that the alternator belt is not broken or loose. Then have the charge system inspected as the battery light is indicating a no charge state, if left for to long the battery will go flat. As for the engine check light, if this came on at the same time it may be connected. Best to get a code read after the charging system is sorted to be on the safe side.
Mark (mhpautos) :D
Wednesday, December 5th, 2007 AT 9:16 PM
Recommended Guides
