1996 Nissan Maxima Manual Transmission
PHILWILL
  • 1996 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • MANUAL
  • 181,000 MILES
I have a 1996 nissan max manual transmission. Accidentally, the car was started I first gear sending the car into a "jolt" after which the car cut off. When I started the car back up, I was able to step on the clutch and put the gear in first, but the car does not move. I also tried putting the car in reverse as well with the same results. The clutch is fairly new. Any ideas? Thanks.
Do you
have the same problem?
Monday, September 6th, 2010 AT 6:46 PM
Sounds like a clutch problem to me.
Tuesday, September 7th, 2010 AT 2:09 AM
Recommended Guides
