2005 Nissan Altima ENGINE LIGHT ON - CAR HAS TROUBLE STARTI
ROBAIR
  • 2005 NISSAN ALTIMA
Engine Performance problem
2005 Nissan Altima 4 cyl Automatic 45000 miles
My engine light recently came on so I had a diagnostic test done which came back with a troubleshooting code- P0340. Since then I've had trouble starting the car. I have to hold the key in the start position longer for it to start up, now it doesn't start at all, it cranks but doesn't turn over. The mechanic said from the code one of the possible reasons could be the timing belt. The code reads 3 possibilties- 1 cam sensor defective-2 check connector and wiring in sensor- 3-engine mechanical condition-timing belt/chain out of time. What could it be?
Do you
have the same problem?
Monday, June 9th, 2008 AT 8:21 AM
KHLOW2008
  • EXPERT
Hi robair,
I would go for the cam sensor.
Monday, June 9th, 2008 AT 9:41 AM
Recommended Guides
