2003 Nissan Altima
2003 Nissan Altima
hi;-) my boyfriend car cranks but it doesn't start. This happened a few months ago and I think he repaired or changed the starter but apparentely that wasn't the problem because it's now happening again so I asked a mechanic and he said that there could be several things but what I wanted to know was if you would be able to narrow it down a little since now that we know that it wasn't the starter.
Thank you for reading this and if you are able to help me out it would be greately appreciated;-)))))))))
Do you
have the same problem?
Monday, November 8th, 2010 AT 10:05 AM
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
4) If all of these things check good, then you would need to do a complete compression test.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Monday, November 8th, 2010 AT 10:32 AM
Recommended Guides
