2009 Nissan Altima Trunk won't open
SPLAVA
  • 2009 NISSAN ALTIMA
  • 2.5L
  • 4 CYL
  • FWD
  • 61,000 MILES
Hi guys,
My Altima's trunk won't open. The Key Fob won't work neither does the button on the console work. The button on the trunk door will not work either. Could this be due to a blown fuse or the circuit breaker. There is no mechanical noise like the normal "pop" when it opens. Any advise would be greatly appreciated.
Thanks,
Matt
Sunday, March 29th, 2015 AT 7:20 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,833 POSTS
Hey SPLAVA,
Test all your fuses first. There is an electronic solenoid that releases the latch that could be bad. Open the trunk using the key and then test of power and the solenoid to confirm its failure. It should open with the key if the latch itself is not jammed or broken.
Use a test light to check for power
and
https://youtu.be/Ho3AykfdzHA
The video is on a Honda but it the same thing to change it on a Nissan
Please let us know happens so it will help others.
Best, Ken
Wednesday, February 15th, 2017 AT 3:45 PM
SPT61
  • 128,000 MILES
Where is the solenoid located for opening my trunk on my car?
Wednesday, February 15th, 2017 AT 3:46 PM (Merged)
STEVE W.
  • 12,942 POSTS
I believe it is part of the latch in the center of the lid.
BOBBYG98ALTIMA
  • 1998 NISSAN ALTIMA
1998 Nissan Altima
for some reason unknown to me my trunk will not open wen I pull the trunk release lever and I cannot turn my key wen it is in the trunk key hole if u could help me to figure out the problem it would b greatley appriciated
Wednesday, February 15th, 2017 AT 3:48 PM (Merged)
ZACKMAN
  • 4,202 POSTS
You may have inadvertently push the lever inside the trunk to LOCK position. That will disable the remote release from the driver seat.
The trunk key hole is probably rusted out. My trunk key has not worked since 1997.
Pull the two tabs on the back seat to gain access to the trunk. Locate the lock latch release tab, close to the trunk latch. Push up to UNLOCK position. Remote release should work now.
TRACY FORD
  • 2005 NISSAN ALTIMA
  • V6
  • 250,000 MILES
All the windows, sunroof, electric seats and the trunk will not work.
JDL
  • 16,098 POSTS
I would have to check your bcm, the bcm controls those systems. Can you check for bcm trouble codes. Some of the national brand auto stores will check codes for free. I'm not sure if they will check manufacturer specific codes, you can call them and ask.
The basic check for bcm would be to check voltage and ground circuit for bcm. Then check signal from bcm to component that the bcm controls. A digital logic probe should be safe for that testing. I'm not sure of voltage on that circuit? So you have to be careful not to put a load on that circuit.
JDL
  • 16,098 POSTS
I's a good possibility your bcm is faulty, but, check the basics, first. Voltage and ground.
JDL
  • 16,098 POSTS
Just to add, some of those fuses are hot all the time. Some go hot with the key on. Check voltages at the fuses with key on, they should all be hot with key on.
Check the ground, also.
TRACY FORD
That could very well be the problem.. My battery light n brake light started coming on when this problem occurred.. Thx so much for the info.
JDL
  • 16,098 POSTS
Hope you get it going your way.
SOLIDMONK
  • 2002 NISSAN ALTIMA
  • 6 CYL
  • 112,000 MILES
Computer problem
2002 Nissan Altima 6 cyl Two Wheel Drive Automatic 112000 miles
hi. My trunk light blinks everytime I put my turning signal on, instead of the green signal, also when I flash on the high beam. My check engine light went on the 1st time it happen. Engine code for the airbag module indicated it was open, I recently changed the seatbelts, engine code for seatbelt retainers indicated. Any ideas? Would nissan have to reset computer for seat belt and airbag?
Wednesday, February 15th, 2017 AT 3:53 PM (Merged)
CLESSLEY1
I am having this same problem, any known fixes yet? It happened after disconecting the battery
CLESSLEY1
Found it a fuse was missing in the fuse block labled electronic parts. There were 2 of them one highlited in white was not there.
