2002 Nissan Altima gasket
THEBUS03
  • 2002 NISSAN ALTIMA
Engine Cooling problem
2002 Nissan Altima 4 cyl Two Wheel Drive Manual
I just rteplaced the thermostat in my 2002 nissan altima 2.5 s. When i was replacin the thermostat i opened what i believe to be the water control valve housing. i thought it was where the thermostat was housed according to my manual. anyways i opened it up slightly and then found the right spot for the thermostat. i closed back up the housing and everything and now i am having a problem with the gasket and the seal i am shooting pressurized hot antifreeze out of the seal. I went to the parts store and they looked at the part and then proceeded to look up a part. they could not find a replacement gasket. my question is what is the part? the gasket? where can i find a replacement? in the picture you will see the housing. i need to know what this is called and what the gasket is called.
http://www.2carpros.com/forum/automotive_pictures/246610_IMG00033_1.jpg
Do you
have the same problem?
Wednesday, September 24th, 2008 AT 6:24 PM
BLACKOP555
  • EXPERT
My list is showing thermostat housing.
Wednesday, September 24th, 2008 AT 7:22 PM
Recommended Guides
