HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Altima
Engine
SPONSORED LINKS
ETC sensor location
KEN031
MEMBER
2001 NISSAN ALTIMA
2WD
AUTOMATIC
122,970 MILES
Where is the location of the ETC sensor on 2001 Nissan Altima GXE 2.4 engine?
Sunday, March 27th, 2011 AT 6:23 AM
MECHANIC
Here is a guide and the diagrams below so you can see how the job is done:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed. Cheers
Image (Click to make bigger)
SPONSORED LINKS
Sunday, March 27th, 2011 AT 6:34 AM
JOE CASTRO
MEMBER
1 POST
1999 NISSAN ALTIMA
4 CYL
FWD
AUTOMATIC
148,000 MILES
Where would the coolant sensor be located on the engine? Thanks BUZZARD
Monday, September 24th, 2018 AT 3:32 PM (Merged)
2CP-ARCHIVES
MEMBER
1998 NISSAN ALTIMA
160,000 MILES
Location of coolant temperature sensor?
MECHANIC
It should be by the thermostat. It has a two wire connector. Here is a guide to help you see what you are in for when doing the job:
Cheers, Roy
Images (Click to make bigger)
TONYS257
MEMBER
1 POST
2002 NISSAN ALTIMA
4 CYL
2WD
AUTOMATIC
150,000 MILES
Need to replace sensor. Where sensor is located?
SPONSORED LINKS
BLUELIGHTNIN6
MECHANIC
On the left rear of engine, on the coolant outlet for the 2.5L engine.
Please
login
or
register
to post a reply.
Related Engine Content
Do You Have A Diagram That Shows The Location Of The...
I Am Needing To Replace The Coil On Cylinder #2 But Am Not Sure Which One It Is
Asked by
jamieleejames
1 IMAGE
2002
NISSAN ALTIMA
GUIDE
Code Reading
A check engine light, also known as a service engine light, or a MIL (malfunction indicator light) is designed to let you know there is a problem with one of your car's...
1995 Nissan Altima Engine
Is There Any Difference Between A 95 2.4 And A 98 2.4 Liter?
Asked by
nateizg0d187
1 ANSWER
1995
NISSAN ALTIMA
2004 Nissan Altima Hestating
Engine Performance Problem 2004 Nissan Altima 4 Cyl Automatic 82,000 Miles Why Is The Car Sounding Like A Truck And Hestating
Asked by
Laamerica
1 ANSWER
2004
NISSAN ALTIMA
SPONSORED LINKS
Hybrid Engine
Hybrid Car
How to Change the Oil and Filter Toyota Prius
Online car repair manuals
