2002 Nissan Altima car not starting tries but will not, turn
DOUGROSE
  • 2002 NISSAN ALTIMA
Engine Performance problem
2002 Nissan Altima 4 cyl Front Wheel Drive Automatic
car starts sometimes and runs fine then I let it cool off it want start, let it sit awhile it starts but misses for 15 seconds?Then smooths out, but now it tries to but will not start, checked fuel pump, injectors there ok, its firing, plugs are fuel soaked have seen several recalls for crank, cam sensors, and to reprogram computer.
Do you
have the same problem?
Sunday, March 22nd, 2009 AT 9:12 PM
Checked fuel pump. How did you checked it?
Plugs are fuel soaked. Might not be sparking and not burning the fuel or the fuel pressure is too excessive or the injector is sticking
Sunday, March 22nd, 2009 AT 9:23 PM
DOUGROSE
Fuel pressure is 48 psi, injectors are not leaking I checked it with a fuel pump pressure tester! It is firing or it would not try to start I pulled each coil and tested them including the plugs. There ok!
Sunday, March 22nd, 2009 AT 11:12 PM
Recommended Guides
