2001 Nissan Altima Nissan Altima 2001 shakes at high speed
BLUESCORPIO7
  • 2001 NISSAN ALTIMA
  • 4 CYL
  • 109,000 MILES
My Nissan Altima 2001 runs perfectly fine till I drive it at 65 MPH but as soon as I cross it it started to shake. Also it make some noise when I cross 70 MPH ( like belt or chain squealing)
Also it shakes while I start and change the gear to Reverse or in Drive.
Recently I changed the engine mount. Pulley in timing chain etc.
Please advice.
Do you
have the same problem?
Thursday, January 1st, 2009 AT 4:49 PM
GFIMOTORCARS
  • EXPERT
I would consider the following. Did this problem being after the motor mount, chain, and pulley repair? If so I would say your problem may be related to the repair. Also check the vehicle while parked. With your foot pressed on the brake and handbrake pulled, rev the motor to the RPM range you see at 65+MPH. Do you hear the same noises? Also check that all motor mount bolts are tight.
Friday, January 2nd, 2009 AT 11:43 PM
Recommended Guides
