MAP SENSOR LOCATION
JPROPST
  • 2001 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 205,000 MILES
Where is the MAP Sensor on a 2001 Nissan Altima?
Thursday, June 2nd, 2011 AT 9:59 PM
DOCFIXIT
  • 18,828 POSTS
There is no MAP sensor but there is a MAF sensor which is located at the air filter here is a diagrams below with a guide to help you change it out.
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Friday, June 3rd, 2011 AT 1:23 PM
NAMEXX
  • 1999 NISSAN ALTIMA
Engine Performance problem
1999 Nissan Altima 4 cyl Front Wheel Drive Automatic
hi there,
does altima '99 has a map sensor or maf sensor, or both?
Where is map sensor located and how to replace it? Is it difficult?
Thank you
d
Saturday, October 27th, 2018 AT 7:02 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
MAF sensor.
It is located on left side of engine compartment, in the air intake (pictured below)
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_195.jpg
Thanks for using 2CarPros.com!
NAMEXX
Inspection wrote I failed map sensor and two mechanics told me it's map sensor, but in hayes repair manual I found only maf sensor for altima (no mention of map sensor). On the ilustration you sent it also says absolute pressure sensor on the left side of the engine, where you said it should be maf sensor-i'm still confused. What altima has-map or maf sensor, or both.
Thanks for your prompt reply.
D
BLUELIGHTNIN6
  • 16,542 POSTS
? Vehicle should have both. MAP sensor is on engine air duct near the air cleaner and MAF sensor is on left side of engine compartment in the air intake. Sorry about that, confused myself. Removing both MAP and MAF sensors are both pretty simple procedures.
Haynes book may have the MAP sensor listed as the Absolute Pressure Sensor or the Manifold Absolute Pressure Sensor instead of using the acronym?
