1997 Nissan Altima misfire on cyl 4, is a constant code
JOEMBINGHAM
  • 1997 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 185,000 MILES
New plugs, wires, cap, rotor, # 4 is fireing, I have held a plug to the cover when running, plenty of fire, no change in motor when running and I unplug# 4 injector, I replaced #4 injector 100.00, still no change, what next, use car for scud missle test? Is the computer possibly bad? Can the crank pos sensor cause this?
Do you
have the same problem?
Sunday, April 5th, 2009 AT 10:00 PM
Check the no.4 compression
Sunday, April 5th, 2009 AT 10:18 PM
Recommended Guides
