1993 Nissan 240SX running rich
DAEMON240SX
  • 1993 NISSAN 240SX
I think I already know the answer to this question but I just want to double check. I recently added a Ram intake to my car. When I did I also had to use maf adapters to make the tube fit the maf. After this my car would lope between 1500-3000rpm and then run fine after 3000rpms. I took off the stock MAF and replaced it with a Infiniti Q45 maf. Car doesnt lope anymore but is running extremely rich. What would be causing this? Do I just need to get the computer retuned to support the different signal from the Q45 maf.
Do you
have the same problem?
Sunday, January 29th, 2006 AT 6:15 PM
JACK42
That might work
Wednesday, February 8th, 2006 AT 5:22 PM
Recommended Guides
